Old 04-23-2004, 01:03 PM
Zoom This's Avatar
Zoom This Zoom This is offline
Default Re: 2X4 barrels FLOOD engine on turns
Originally posted by Excaliber
What kind of carbs are you guys with dual four barrels running?
I've got Holley 660's, center squirters. The carbs flood the engine bad:
1. In ANY corner.
2. Under moderate stopping.
Great for drag racing, but I want to go in circles (as in SCCA).
Replace the manifold with a single carb?
Replace the dual carbs with something else?
I THINK I have a high riser manifold.
Ernie....I have an 850 Holley double pump w/mechanical secondaries for sale with chromate plating that is only 6 months old with 2000 miles on it. It's really too much carb for my 418 stroker on the primary side. It has #80 jets on all four corners, #35 accelerator pump nozzles. The metering block has been modified so it will not drool gas back into intake manifold after run hot. If you are interested, $450 will get it to you. See my gallery for pictures.
Zoom
