Old 04-23-2004, 08:29 PM
kountzecobra's Avatar
kountzecobra kountzecobra is offline
I knew you could help it Ernie. Just keep at it. Its worth the effort.
Jet size should be in the ballpark. Maybe 67 or 66? Just make sure you don't get a lean surge at cruise speeds. Idle mixture is VERY important up until hi-midrange speeds. Adjust at idle with a non-damped vacuum gauge. One carb at a time, back and forth until each is best. I usually back off of idle speed on the carb I am not adjusting at the time. Adjust linkage correctly too. And most of all: have fun!
David Shelton
Lone Star Gashole!
