Old 04-25-2004, 10:33 AM
Michael C Henry Michael C Henry is offline
Cobra Make, Engine: Everett Morrision FE 427 so 2-4s
Default wiring-dependable or nostalgic?
I like to look at others cars and see the choices they made. Now I'm redoing the wiring.I've installed two relays on the fans,don't want to burn up those two thermastatic switches.I plan on installing two relays for the headlites,I have burnt up a headlite switch at 2:00AM.Drove home by the flashes of t6he 4 ways,where is that curb?And don't want to burn out the column dimmer switch.
I want to control the ignition and fuel pumps in the event of an accident I plan on controling the relay ground thruogh the oil pressure switch.
Also had a problem with the original glass fuses left me dead at a stop lite. Rain had dripped on the fuse bord on top of footbox = bad connection.Went to miniture blade fuse block with a removable cover.
Horn relay ,Ignition relay, accessory relay ,low beam relay,high beam relay, lower fans relay upper fans relay.
The relays are replaceable and cheap easy to find. Thoughts?
Mike H
