Old 04-27-2004, 06:27 PM
Michael C Henry Michael C Henry is offline
Cobra Make, Engine: Everett Morrision FE 427 so 2-4s
I'm installing a new Mallory HyFire VI ignition box .Mallory has as you know comes with a bypass plug to return to dist-coil operation(drive it home). They reccamend using the ballast resister in that event. I bought the Mallory #700 ceramic resister. How hot does that get?I have removed all the wires from the intake manifold and ran them all along the wheel wells. I'm afraid of bolting the resister directly to the fiberglass.Any reccamendations?
Oh! and the headlite switch was the push -pull type with the glass fuse on top.The fuse contacts were all blue and loose. It was 2o AM, the dew had set and I proped thehood open on the latches and used the engine heat to clear the windsheild.The 4 ways don't flash often enough navagated a dark road with curbs ,at any decent speed.
Mike H
