Old 04-27-2004, 08:24 PM
Carb solves a LOT of problems, good call.
Cam swap is not that hard but will be costly. Plan on lifters as well as a new cam. With the "older" engine are you sure you WANT to swap cams? Maybe you will like the low end torque, I did! And I found it more useful running SCCA than a high rpm cam would have been.
