Old 04-28-2004, 08:19 AM
trularin's Avatar
trularin trularin is offline
Member of the north
Cobra Make, Engine: A Cobra
Here again Aumoore is correct.
The spring will need to be replaced if your are going to step the CAM up a bit.
While you are at it, why not balance the engine and rebuild it. New rings, gaskets, seals, CAM and timing chain ( double roller ).
For that matter, you could probably rebuild the one that is in the car for $900.00.
If you have to do a bone yard engine, get the explorer motor.
Just my $0.02
