Yea Petec the streets are dry....warm enough? well that's a matter of opinion, I'd wear a snow suit if I had to.
Don,
That makes a lot of sense considering where the actuator rod is located on the pedal. Looking forward to the revision. I just may buy the whole pedal box assembly from you. I don't like the pedals and I read that you are using the AC pedals from FINISHLINE. My brake actuator rod has been spot welded to the pedal link, which I don't like either. Do yours come with an adjustable link? Also my accelerator pedal doesn't have enough travel to open my secondaries all the way and the offset from the brake and clutch pedals is excessive. Having a donor accelerator pedal that has been cut in half looks cheesy...having my carburators' performance cut in half is unaccaptable. I have been considering using the three pedal underslung configuration from AP RACING and just eliminating the power booster alltogether. If their pedal box was a 1/2" smaller I would do it in a heartbeat. Would you mind posting a picture of your pedal box and pedals (installed)when you have completed the fabrication? I have included a composite showing the accelerator offset and the spot weld on the brake pedal actuator. Is the booster actuator rod an integral part of the booster or can I replace just the rod with a two piece adjustable link?
