Old 04-29-2004, 06:49 AM
TC Cobra's Avatar
TC Cobra TC Cobra is offline
Cobra Make, Engine: Classic Roadsters; 351w, Crane Cam, AFR 185's
Hey Don!
I have some “final” ;-) wiring questions:
1. One of the small bundles coming out of the fuse block has a connector with six male spade terminals - #’s 152, 127, 130, 146, 114 & 156. It also has two separate leads for #’s 146 & 156. There is not a corresponding connector to plug this into. What should I do with it? (I’m not using one of the components anyway eg. A/C, others I am using) Also, the manual says the separate lead for #156 goes to the emergency brake switch. Where is the e-brake switch?
2. The red warning light (brake) on the dash has #130 connected to one of its terminals. What connects to the other terminal to complete the circuit at the proper time?
3. Do the sockets for the turn signals and the four-way flashers use the same type of flasher unit? (536?)
That’s all for now!
Thanks for your help!
Dwain
