I had 1/4" by 6" plate welded to the frame rails under the seats about in mid shoulder/hip line. Drilled through the seat bottom and plate there is just enough room under both seats to fish the strap and mounting plate then bolted them in with grade 8 bolts and nylocks. Sounds easy but is a pain because I had to pull them a couple of times and reinstall after making length adjustments on the strap. My seat belts were a problem as there was no possible way to weld in a plate due to the frame design, so I used about 1/4" x 6'' x 10'' plate for each side of the belt bonded to the cockpit tub with epoxy and then drilled holes for the belt attachments. Only way I could figure out how to do it and have it secure, figured if it came to "down" it would have to tear through 1/4'' of fibreglas the length of the plate before letting go. I hope.
My shoulder belts are "Y" type and there were attachment points built into the frame for this type and they come up through the trunk deck.
"Breathe in... Breathe out... then move on with life. Lifes too short to sweat the small stuff"
