Old 04-29-2004, 05:54 PM
peterd peterd is offline
Default AFR heads
i have attached the spec for my 351-> 408 stroker with AFR205 heads. I would suggest if you want to compare options use desktop dyno. The numbers will be at the flywheel and are only as good as the data you enter, however it is great for looking at relative results
