Old 04-29-2004, 07:08 PM
dscott's Avatar
dscott dscott is offline
Cobra Make, Engine: Owner, Classic Roadsters II
Dwain, you really aren't feeding 12 volts to the sender. You are supplying a ground circuit. The bulb takes the 12 volts and acts as a resistor and uses up the voltage and turns it into heat (light).
Don
