Thread: help needed
Old 04-30-2004, 04:51 PM
Bruce Edwards's Avatar
Bruce Edwards Bruce Edwards is offline
Cobra Make, Engine: Hunter with a 4.6 supercharged
Ok professional trick. Place a breaker bar on the crank bolt. Turn the engine with the breaker bar till the bar is sitting on the frame. Be SURE that you are turning the engine the way it turns when you start it. Once the bar is on the frame hit the starter and the bolt is now loose.
One other thing to remember DISCONNECT THE IGNITION!!!!
Bruce Edwards
Gemini Motorcars Inc.
http://home.bellsouth.net/p/PWP-GeminiMotorcars
