Old 04-30-2004, 10:03 PM
Rick 427 Cobra Rick 427 Cobra is offline
Cobra Make, Engine: HI-TECH 289 FIA
Iwas told that the drive line is offset 5/8" to the pass side. Thats the way mine is set. As long as the drive line axis and the pinion axis are parallel and the tail shaft and pinion faces are parallel there should not be a phase problem. You didn't use the 428 flywheel on the 427 did you?
fiaroadster
