Old 05-01-2004, 03:05 PM
olaf herrick olaf herrick is offline
we hooked up an engine analyzer , inserted the O2 sensors behind the headers . The readings are correct , I was told that eventually this condition will foul plugs, provide worse gas milage (not sure if thats possible) and a loss of some power . I know my car will make you cry from the rich mixture if your in a confined space. The factory power valves are set at 6.5 psi which appears to be an OK setting . It just seems to me that if I can get the carbs in the power circuit sooner my problem wouldnt exsist. I'm going to try and adjust the linkage as Viking suggested. Olaf
