Old 05-02-2004, 07:43 AM
edwhite7 edwhite7 is offline
Cobra Make, Engine: Contemporary, Shelby Alum 427, Dove heads
Excaliber is correct. The carb setup is dependent on the manifold type, single plane or dual plane. In the Tunnel Wedge design which is a single plane, each cylinder has acess to both carbs. In the dual plane design which is the most common dual quad manifold the carbs are split and each cylinder only has access to half of each carb. Because of this design a dual plane usually can run a bigger carb that a single plane.
In school 90% is exceptional, in life 10% wrong is failure.
