Old 05-02-2004, 11:30 AM
SCOBRAC's Avatar
SCOBRAC SCOBRAC is offline
Cobra Make, Engine: -Sold- Contemporary 427S/C # CCX-3152 1966 427 Med Rise Side Oiler, 8v 3.54:1 Salisbury IRS, Koni's.. (Now I'm riding Harleys)
Thumbs up Driveline Specialties
Thanks Rick,
I got my driveshaft back in 5 hours from Driveline Specialties in Sacramento. Amazing, they squared up the yoke, replaced the driveshaft end that the yoke mates with, replaced the u-joints painted it and balanced it for $104.
The bad news is I still have the vibration. I suspect it is all in the pinion and tailshaft angles. 3 degrees is said to be the maximum for such a short shaft, including any for offset. I'm probably closer to 5 with the elevation (up/down) and offset (left right).
I have My tailshaft is pretty much dead center between the frame rails My pinion axis is more like 1.5" to the passenger side, as measured between the frame rails it's 8 3/8" off the passengers side tube and 9 7/8" off the drivers. The Contemporary differential is intergral with the frame at that point and has no real provision for adjustment there.
I may need to bring the tranny over to get a net offset of closer to 5/8" total. I also noticed the headers seem lower in front than when the 428 was in place I think raising the front of the engine, while lowering the back of the transmission is next to bring the 5 degrees closer to 2 or 3 total...
No... I didn't use the 428 flywheel
michael
A man that is young in years, may be old in hours, if he have lost no time. But that happeneth rarely. Generally, youth is like the first cogitations, not so wise as the second. For there is a youth in thoughts, as well as in ages... Sir Francis Bacon (1561-1626)
