Old 05-03-2004, 10:20 AM
Hotfingrs's Avatar
Hotfingrs Hotfingrs is offline
Cobra Make, Engine: EM cobra, 450 inch sbc running a best ET of 9.14..so far..ALL MOTOR...approx 800 horse.............ERA with 482 FE..All Aluminum Engine
Send a message via Yahoo to Hotfingrs
There is nothing in the pipe, but the baffle. If you look at the picture in the first post, you can see a tab on the right end. There is also one on the other end. You would drill 2 holes on the backside of the pipe to corresponde with these tabs. The tab has a nut on it, so a small allen head bolt holds the baffle in place. The baffles can also be made to any length and are generally 3 1/2 diameter, but can also be made to any diameter.
Jack
XSSIVE .....
