Old 05-03-2004, 10:29 AM
RallySnake's Avatar
RallySnake RallySnake is offline
Yoi,
I had a similar problem. It was caused by the air filter. I hammered a little dent in the spot where the upper part of the carburetor lever was rubbing and solved the problem. Unless, I forget and put the air filter on backwards!
You do have two throttle return springs, right?
Paul
