Old 05-04-2004, 07:53 AM
bmcmillan bmcmillan is offline
Cobra Make, Engine: B&B non-donor, 496 Genesis SO (608 HPwith 9.4:1 CR), Tremec TKO, Currier 8.8
trularin,
Mechanical. It works for a few miles - not enough to see if I am using the correct gear for my rear end ratio and tire size - then the gear strips. It doesn't look like the driven gear is engaging enough.
Do you know if the gears with more teeth are physically larger? If they are, I might need to use a larger gear even though the speedo won't be correct.
