Old 05-05-2004, 06:08 AM
Ron61's Avatar
Ron61 Ron61 is offline
Post
A1,
Less teeth should speed the speedometer up. The norm is about 4 MPH per tooth each way. Maybe try dropping down three teeth and see if you notice any difference. If not, then maybe the drive gear in the transmission itself will have to be changed but that is a job as you have to pull the transmission. I have also read on posts about adapters for speedometers but don't remember which ones they work on. Some of the others can give you better information on that.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
