Old 05-06-2004, 04:12 PM
Edley Rondinone Edley Rondinone is offline
Cobra Make, Engine: NAF replica, 351W, about 420 HP
I use MetalWax. It is a two-stage process; first stage is a gentle acid that goes on with a watery rag to clean the surface. Wipe dry with a separate cloth. Then use the Wax. This company says that the compounds leave a lit of microscopic grit, which attracts dust and dirt, thus clouding up the surface, thus requiring MORE compounding, which leaves the girt, etc etc etc.
Go to a Harley motorcycle show, the ones with all sorts of vendors. There is usually some guy with a metal polishing system that polishes the bottoms of aluminium cans, as samples.
Edley, The Cobra Rogue!
"If you think that you can cut it, if you think you got the time, you'll only get just one chance, better get it right first time. 'Cause in this game you're playing, if you lose you got to pay, and if you make just one wrong move, you'll get BLOWN AWAY. Expect no mercy.
