Old 05-07-2004, 02:12 PM
DonC's Avatar
DonC DonC is offline
Cobra Make, Engine: ERA #684, 428 FE, TKO600
Make sure that both ends of the cable housing are firmly attached. If they aren't the housing will flex and won't have the rigidity it needs to function. If they are and you're still getting spring back in the cable shorten the cable housing and cable to a more appropriate length.
DonC
