Old 05-08-2004, 10:32 AM
justa6 justa6 is offline
Default Clois and Rick
Hi guys...
Just a thought about the problem Clois.
I had the "6" do the same thing. Here is how I fixed it. First if the K&N are mounted on the valve cover they are not "vertical" so when some oil gets blown into them they CAN'T drain back. the oil goes to the lowest (outside) side and dribbles out through the filter material. I made an "extension" that made the filter vertical and then went to a lawn mower shop and got some AIR FILTER material (the foam kind that needs to be oiled). Then you cut a piece that will fit into the neck of the filter. This allows the air to pass but blocks the oil. Works great...
Hope all is well with you both and hope to see you at R & G this year.
Bob
Johnex Cobra, Buick V6
