Old 05-08-2004, 04:41 PM
Chaplin's Avatar
Chaplin Chaplin is offline
Cobra Make, Engine: Original ERA 427sc, Powered by Gessford
Luke-
What is your engine set up? What heads, cam, compression ratio, etc?
What jets do you have in your primaries/secondaries?
I had the exact same problems you are describing and I finally put my car on a chassis dyno this week to tune the carb. What I found was the motor was running very lean, which caused the same type or lean miss/hesitation and seeming lack of power that you describe.
The jets in my carb were 75 in the primaries and 83s in the secondaries (I have a mighty demon 750 with mechanical secondaries). I had to re-jet it to about 84s in the primaries and 92s in the secondaries. (I am going to experiment with going down on the primaries some b/c I pulled the plugs today and they actually look a little rich now). But WOW what a differnce. It runs like a different car now and the power is now finally what I expected it to be.
I would bet that you are also running too lean.
Hope this helps.
Replica is not a dirty word.
