Old 05-09-2004, 05:35 AM
strictlypersonl strictlypersonl is offline
To find out whether the problem is too-far-advanced ignition or bad starter/tight engine, disconnect the coil wire. If the engine turns over faster, the ignition is too far advanced - you'll need a different distributor curve.
If the engine still turns over slowly, you'll have to test the starter.
