Old 05-09-2004, 12:49 PM
terry lee's Avatar
terry lee terry lee is offline
GEAR GRINDER CUM LAUDE
Cobra Make, Engine: SPF #1560 w/ Ford Racing [RDI/AFR/RPM] Alum. 427CI - 575HP & TKO
YOI,
Many of us with SPF's have experienced this problem.
More than likely it is the throttle linkage. Unfasten each ball connection and grease the fittings. This should eliminate the problem. There could be some other problem, but this solution seems to work in most cases. Also check to make sure the assembly is not hanging up when it makes its bends. This has been discussed at some length on "SCOF" the SPF forum.
TL
BOYZ and TOYZ
With every day I grow alittle older -
BUT, I'LL NEVER GROW UP!
