Old 05-10-2004, 05:54 AM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
What distributor are you working with?
On your Blaster Coil use the big black boot that will slip over the top of your coil. Slide your boot up your wire and install your brass terminal to your wire. If you are not using a new set or wires you may need to cut off you old distributor wire boot.
Sorry I can't be of more help.
Clois
"Let's roll"
"Be part of Something Good
