Thread: TKO II from 2-3
Old 05-10-2004, 08:01 PM
Chaplin's Avatar
Chaplin Chaplin is offline
Cobra Make, Engine: Original ERA 427sc, Powered by Gessford
Mike,
Pro 5.0 is higher than the stock shifter and doesn't fit well in the ERA trans tunnel. In fact, I ruined one trans tunnel trying to get the Pro 5.0 shifter to fit properly I had to order a new trans tunnel, and after speaking to Doug at ERA, just decided to use the stock shifter. I suppose you could make a spacer tall enough to make it work with the Pro 5.0, but it would probably look ridiculous. As it is, you have to use that 3/4" spacer with the stock shifter.
I am also using the GM Synchromesh fluid and haven't noticed and real problems shifting. I've got about 1300 miles on it now and the shifting seems to be improving with mileage.
Replica is not a dirty word.
