Old 05-11-2004, 04:43 PM
dscott's Avatar
dscott dscott is offline
Cobra Make, Engine: Owner, Classic Roadsters II
Bob, if you are using an aftermarket ignition system like the MSD you can eliminate the ballast altogether. If you are running the stock Ford ignition box they do develope a problem that you described. Having to back off the key while cranking is usually in the box itself. There is a terminal on the fuse block for a 12 volt ignition source if you wanted to do that. I don't think you need to. Sounds like one of the problems I discussed. Good Luck!
Don
