Thread: CV Joint
Old 05-12-2004, 06:37 AM
craig craig is offline
Cobra Make, Engine: FFR2521
The axle is connected to the cv joints. The outside cv joint is attached to the outside half shaft with c-clips or retaining rings. The inner cv joint is free to slide in and out of the inside plunger style half shaft. The inner half shaft is held into the pumpkin with a c-clip. To remove the inside half shaft from the pumpkin pry carefully with a larger screw driver. It will pop out with little effort.
Craig
www.vpmcobras.com
