Old 05-12-2004, 06:50 AM
davidlee davidlee is offline
Cobra Make, Engine: sold BDR #123 351w, Tko 17" full polished wheels
Dan,
This is a new carb.
MR fixit,
Last night I swaped the front to the rear squirter. The factory had a 28 in the front and a 32 in the rear. I noticed no change when I reversed them. All I can say about the "stumble" when I take off normally I hit prox 2000 rpm the power goes flat almost like you turned the switch off for a nano second then launches off.
Am I looking in the wrong place?? Could it be something other than carb? I have a Ford duraspark dist and a msd 6 ign box. The only two consistant things are carb adjustments made no difference and the problem always occurs at prox 2000rpm. Thanks for all your input.
David
