Old 05-12-2004, 03:24 PM
CJ428CJ's Avatar
CJ428CJ CJ428CJ is offline
Cobra Make, Engine: ERA #629, BBM Side Oiler Block, 482ci, Richmond 5 speed
Blykins,
Have you played around with any of the dyno software simulators like Dyno2000? You can try all kinds of different cam, compression ratio, valve, header combinations, etc. to see what might work best. Some people say Dyno2000 is just a "toy" but I have yet to see anyone post any Dyno2000 numbers vs an actual dyno run that varied significantly. Besides, you've already run your engine on a dyno so you can plug your current specs into Dyno2000 and see how close it is to your actual measured values. That should give you some sense of confidence (or not) that the specs you plug in give reasonably accurate numbers.
Chris
