Old 05-13-2004, 05:33 PM
VBarnett VBarnett is offline
Cobra Make, Engine: Velocity - SPF 738 396 SB.
Dan, Hal, thanks.
I made the adjustments as suggested. The busings are fine, and the handling is only average at best. I am convinced the car is over sprung.
I tossed in a few sacks of kitty litter (you use what you have) and found the car rides much nicer two hundred pounds heavier.
I wonder if SPF designed the suspension for Big Blocks?
In any event tnis chassis should handle much nicer than it is. My general point of reference is 99 Neon RT daily driver and a Rabbit GTI. Velocity's suspension is not an old design,
I am told replacing the AVOs/Springs with SPF's newer shocks will make a significant difference. Hal, you replaced your AVO's. Was it worth it? What differences do you notice and waht are you using.
I appreciate the help in making Velocity live up to her otential.
