Old 05-13-2004, 07:47 PM
G.R.'s Avatar
G.R. G.R. is offline
Cobra Make, Engine: NAF 289 FIA, 347 stroker with Weber 48's, building a '48 Anglia gasser, driving a '55 Chevy resto-rod
Send a message via Yahoo to G.R.
Make sure they are stainless--easy way put a magnet on them if it sticks buy stainless---tape your dash before drilling, helps to keep the glass and paint from chipping--drill one size under the screw screwshank ie: 1/8th shank use a 3/16th bit or a 7/64th bit-----use a silicone (RTV works great)as a lubricant and glass sealer---DON'T use a power driver---thread it in by hand, if starts to bind(it will), back it out and re-lube, try again, the screw will usually begin cutting threads again---I always have extra S/S screws of the size I need on hand, if the screwdriver slips you'll screw up the head, if you force the screw you will more than likely pop the head off--after you have drilled the holes re-lube the screws then mount the mirror.
I've installed a lot of equipment on boats in the last 20 years and this method works. Have used it on my car also.
PS--the Screws sent w/ my Finishline mirror were S/S-- hasn't wiggled or come loose yet from vibration.
"Breathe in... Breathe out... then move on with life. Lifes too short to sweat the small stuff"
