  #37 (permalink)
Old 05-14-2004, 09:43 PM
Johan's Avatar
Johan Johan is offline
Center lock nuts/ spinners should be torqued to 400 ft./lbs.
This is common knowledge in the pits. Using a gun we have to hook it to a big nitrogen bottle to get the suckers loose. At 400 lbs. they still need to be checked after every run as they may have loosened 3 degrees or so. Also, remember the temp of the assembly matters.
I use a torque wrench(48" long 3/4" drive).
