Old 05-15-2004, 12:31 PM
mikey mikey is offline
Default Fuel Pump cut off switch - help please
I am connecting my electrical fuel pump via an oil pressure safety cut off switch and need to clear up some confusion with the wiring diagram.
The diagram shows one of the swith terminals wired to the ignition and the other wired to the starter with the main feed going to the fuel pump +
Is this wiring on top of the existing wiring to starter motor and coil or does this replace the original connections. Allso anybody know which terminal on the Chevy starter it is meant to connect to as it does not make this clear.
Your help would be much appreciated.
Cheers Guys
Mike
Mikey B
