Old 05-16-2004, 01:32 PM
Cobra 29 Cobra 29 is offline
Cobra Make, Engine: ERA 427SC FMS 351W
Default Tips for removing hub carriers & half axles
Paul and others, I need to remove and send my hub carrers, hubs and half axles to ERA to have the hub carriers replaced. The bottom pivot bushings sre installed incorrently and the carriers have developed fine cracks. The car and rear end was NOT assembled by ERA. What is the easiest way to remove these parts. Can I get to the 4 nuts near the rotor with hand tools or do I need to use an air impact gun?
Era will replace the hub carriers, inspect / install new wheel bearings, setting the clearances and replace the lower pivot plastic bearing with proper tappered bearings and set these clearances.
Any suggestions on removing / installing this sub-assembly would be appreciated. Thanks
