Is the throwout bearing supposed to slide all the way onto the outer shaft on the TKOII? You have the pilot part of the shaft, then the "teeth", then a larger smooth shaft that runs to the gearbox. I assume the throwout bearing should slide onto that larger outer-most sharft, but the bearing is too small. I measured it with my caliper it is 1.37" (1 3/8"). The outer shaft is about 1.43"
Sorry for the dumb question...this is my first time messing with one
