Old 05-19-2004, 05:26 AM
Jim Maxwell Jim did you try and jump start the cobra with another car or truck running with a GOOD set of battery cables? What Happens?? If it is fast clicking, with the car running put the cobra in neutral, parking brake on the take the pos cable and hit the S terminal and starter terminal at the same time. The starter motor should crank the motor, if not you need a starter. Get a gear reduction one, they crank a little slower but are stronger. Have you checked the fluids? Are they all full?? Try and turn the crank over by HAND wrench, make sure it moves. If not put all the spark plugs and crank it over, UNHOOK the coil and fuel FIRST. Let us know what happens. Rick Lake
