Old 05-19-2004, 04:44 AM
Rickster Is it apart or together? Hear it run if together for 5-10 minutes, let it get to operating temps, and listen for noises in the motor. If apart Tell him you want to go to a machine shop and have it checked, Pay half and PUT IT ON PAPER, both sign it and a 3rd person also, bring a friend. Try and get as must info as possible. Get any numbers you can off the heads, crank, dampener, pistons, intake, or block stamp area. Give him a Deposit to hold for a day or 2. If there is no problem, he should let you, if not walk away. You will find another. A couple of motor may be at Carlisle this week end. First week in june the big Ford swap meet is at Carlisle. The first motor I got was to be a 428 and turned out to be a 410. 428 crank and a 390 bore block. Messure the bore and stroke if apart with a caliper. Good luck Rick Rick Lake Ps if I see any fe's at Carlisle I will give you there number. Have you checked with the one ERA uses?
