Old 05-20-2004, 07:50 AM
sharpe 1's Avatar
sharpe 1 sharpe 1 is offline
Cobra Make, Engine: Midstates,SBF 357
Ford starter relays are externally grounded and it sounds like you have lost that ground. You can check it by running a ground wire from the relay to a good ground on the car. Then try to start
it. If the ground is good it should start.
