Old 05-21-2004, 04:29 AM
trularin's Avatar
trularin trularin is offline
Member of the north
Cobra Make, Engine: A Cobra
Intense.
The voltage regulator shouldn't have anything to do with the MSD box ( at least I don't think so )
Anyway, your alternator has three important wires attached or should be attached to it. A #10 wire that goes to the battery. it is usually marked "Batt" it is the red terminal on the part. There may be one or two grounds. These look like connection terminals, but are NOT. From what you indicate, you might have connected something to one of these.
Anyhow, there is a "Field" terminal which connects to the four terminal voltage regulator on the connector marked "FLD". On the alternator the three terminals will be isolated with plastic washers, these are NOT grounds.
ANd the last terminal is the "Stator". It is rare, but the stator is usually not connected. If it is used, it is a wire that goes between the Alternator and regulator. It is the termianl "STA" on the regulator.
The regulator has four terminals plus the frame. The frame is the ground and MUST be grounded ( engine ground is real good ). The terminals are "I", "A", "S", "F" on regulators that are the new electronics versions. "I" is for ignition, "A" is for Alternator ( the battery connection ), "S" is for Stator, generally not used but is a nice indicator the alternator is working and "F" is field, this must go to the alternator or it will not work.
In it's most basic form, connect the battery terminal from the alternator to the battery and the "A" terminal on the regulator. Connect the "FLD" terminal on the alternator to the "F" terminal on the regulator. DO NOT connect any other wire and run the car.
If you get voltage from the stator on the alternator, it is working. Check the voltage at the battery. It should be no more than 15.2V ( I think ).
It has been a long time since I worked on this, so if I got the stator and field mixed up, SORRY.
Just trying to help.
