Thread: Front tire size
Old 05-21-2004, 04:24 PM
A Cobra guy A Cobra guy is offline
Cobra Make, Engine: E-M , 5.0 efi
Jerry, I'm running 245 /60 /15s on my EM. The fit nicely under the fenders. I see you have a jag rear. What is the front? Mine is the Mustang 2 geomintry (sp?) You can adjust the toe with shims. My guess is the problem is a-arms or spindles or both. None of the above will be cheap to change, so trying toe in and narrower tires makes alot of sense.
FYI I am running Yokohama Avids this year. THEY ARE GREAT. Much better than the Goodrich's I took off. If they make it, I'd bet the narrower Yokohama will corner just as well if not better than the Goodrich.
Harvey R
