Old 05-22-2004, 04:33 PM
timsullivan's Avatar
timsullivan timsullivan is offline
Cobra Make, Engine: Superformance SPO2820 408W; former ERA CCX 3-3408 owner
Default Contemporary Brake Mst Cylinder ID?
I have an older Contemporary cobra ( CCX 3-3408) with a leaking master cylinder resevoir (sp?). It is a one piece cast unit consisting of both the brake and clutch master cylinders in one cast unit. The cover for it is rectangular shaped about 3.5 inches by about 2 inches. It has "made in the USA" cast into it with each protruding cylinder labeled "brake" and "clutch" cast into it. I have the hanging pedal assembly with the master cylinder mounted above the pedals and projecting into the engine compartment. Any idea what make or brand this master cylinder is? Thank you for any help you can give.
