Originally posted by rbray
Hi Guys,
I'm going to use the setup labled Without ignition light in the above diagram. Does the dotted line labled from battery mean that I must run a wire to the battery? ( sorry for the stupid question). What size wire should I use and how do I attach it to the battery?
Thanks for the help, as you can tell I am not an electrical expert
Hey Rick, you're usually right on the money...
But the BATT lead from the alternator is most often connected to the same terminal on the starter solenoid with the positive cable from the battery.
- Jim -
