Thread: TKO II from 2-3
Old 05-23-2004, 07:22 AM
Chaplin's Avatar
Chaplin Chaplin is offline
Cobra Make, Engine: Original ERA 427sc, Powered by Gessford
Default Re: Removing ERA 427 Tunnel
Originally posted by Cobra 29
Chaplin, I believe I need to remove my tunnel to gain access to my 3550. Any suggestions to more easily remove and install these tunnels on the ERA 427 cars?
Thanks, Dave
Dave,
Unfortunately there is only one way to do it, which, as I'm sure you know, requires removing the seats, carpets and rear panel. However, once you've done it a few times it gets easier and easier. Just use an electric drill with a screwsdriver bit to remove/reinstall and the screws and it will go a lot faster. I can probably remove mine in 20 minutes or so at this point.
Replica is not a dirty word.
