Old 05-23-2004, 03:11 PM
Bud Man's Avatar
Bud Man Bud Man is offline
Cobra Make, Engine: Former Owner/Builder of KMP142 427 Sideoiler, Tunnel Wedge, Aluminum heads, etc.
Red:
Assuming you have had a quality coating applied to your header pipes, (inside and out) I will offer a few suggestions:
First, it is important that your footboxes and firewall be carefully sealed to eliminate as much engine/exhaust heat as possible from entering the cockpit. Using the correct weatherstripping and a little patience, you should be able to do this very easily.
Second, I would thoroughly insulate the footbox surfaces where they face the engine compartment. While the traditional method has always been glueing a high quality insulation such as Thermo Tec, another very effective, more modern method is to use polished stainless steel sheeting that is cut to the dimensions of the footbox surfaces and mounted using screws and spacers (washers) that allow a few millimeters of airspace between the stainless steel and the surface of the footbox. While not traditional, it is very effective as it not only insulates but reflects the heat back due to the polished surface.
Insulation under the carpet won't hurt, either, but the above is, I believe, the most effective ways to deal with the heat problem.
Hope it helps. Good Luck
Bud
