Old 05-24-2004, 07:26 AM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
Yes, you need a block plate.
The TO shouls not be in constant contact with the pressure plate fingers. Push TO so it is fully compressed. AT that state it should have .100"-.125" clearance to the pressure plate fingers. (prior to being hooked up to clutch master cyl)
The McLeod TO has a collar that threads in/out to adjust how far on the input shaft it extends. Screw it in a litle more to get the clearance you need.
