Old 05-24-2004, 10:01 AM
Zoom This's Avatar
Zoom This Zoom This is offline
Go to this web site http://www.holden.co.uk/ and you'll find what you need. I went through this same thing because I found the original bulbs in the gauges to be way too dim for night driving also. The wattage in the original Sylvania's are 2.75. At the Holden web site, go to the e-catalogue link, then to lighting. The ones you will want to order are LLB501, rated at 5 watts. As much searching as I did, this was the brightest I could find from any distributor. If your high beam indicator lamp was as bright as mine was, you can cut that in half with one of the replacement bulbs from Holden. Hell, I had to either drive with my hads over the high beam indicator while it was on or put tape over it.
The bulb I used as a replacement was LLB281, rated at 2 watts. Turned out to be a perfect replacement. I left the turn signal lamp indicator as is (bright) since it is useful during the day to be so bright. Overall, the gauge illumimation increased by about 50%.
The only one I couldn't replace was the Smiths tachometer bulb. It's an odd duck that I haven't been able to find a brighter replacement for. Anyway, you'll like the increased brightness of all your gauges when you're done. The gauges above the speedo are easily accessed after you remove the speedometer. Make sure you disconnect the battery before putting your fingers and hands inside the wiring to avoid any shorts etc.
Remember to lower the fuse box on the drivers side before trying to remove any bulbs on that side of the dash....makes life easier. Good luck.
