Old 05-24-2004, 11:54 AM
scootter's Avatar
scootter scootter is offline
Cobra Make, Engine: SPF #1436 514
In the back of the tach is a rubber plug. If you take that plug out it is behind that. You have to turn it then pop it out. I took the tach out of the dash to get it out. You might be able to do it without taking it out if you use a mirror. That light I did not replace or get the numbers off. But I know that it is different from the others.
